Call forwarding unanswered
  • Updated 2 weeks ago
I want to set my home phone to forward unaswered calls to my cell phone. However i also have voice mail on the home phone so i am wondering if that will count as "answering" the call, or will it skip vm and forward it
Photo of lindsay
lindsay
  • 80 Points 75 badge 2x thumb
Posted 2 weeks ago
Photo of Dinh
Dinh, Mobile Master
  • 41,904 Points 20k badge 2x thumb
hi Linday,
I believe call forwarding option on the wireless homephone is a "unconditional" forwarding. Once you enable it, Koodo will forward all incoming calls to other number. Your WHP doesn't even ring. Hence, I don't think you can only forward "unanswered" calls.
Photo of Dennis
Dennis, Mobile Master
  • 196,488 Points 100k badge 2x thumb
You can set it the way you want. See the instructions here
https://www.koodomobile.com/help/101-...
Note that you only hey 2500 minutes of call Forwarding per billing cycle
Photo of Dinh
Dinh, Mobile Master
Nice, I didn't know it can do the "conditional forwarding" :)
Photo of lindsay
lindsay
Yeah i saw the instructions on how to set it up, my question was actually about how it works. For example, if i program it to forward UNANSWERED calls, does voice mail count as answering, or does it go straight to forwarding the call
Photo of Dinh
Dinh, Mobile Master
It will skip the Koodo voicemail and forward the "unanswered" call in that case.
Photo of Dennis
Call Forwarding will always by pass voicemail.
Busy (you are on a call)
Unanswered (you are not able to pick-up)
Unreachable (you have lost connectivity or your phone is turned off)
