Call Forwarding on prepaid
  • Updated 11 months ago
I have a prepaid phone with "$15 Unlimited Messaging" plan which includes Call Forwarding. How do I activate and deactivate Call Forwarding?
Photo of BGD
BGD
Posted 11 months ago
Photo of BobTheElectrician
BobTheElectrician
  • 67,356 Points 50k badge 2x thumb
Call forwarding on prepaid does not work AFAIK. Check all the Related Conversations on the right, but your answer is in this one:
https://community.koodomobile.com/koodo/topics/call-forwarding-on-prepaid
Photo of BGD
BGD
Actually, I found a way in Phone app / settings (on Android) where I changed the number for "when unavailable" from the voicemail to the number I want.
Thanks for the answer, anyway.
BobTheElectrician
  • 67,216 Points 50k badge 2x thumb
You've lucked out. Hope your fix survives your next reboot.
When I do the same on LG G3, Android 6, I get a Call settings error. Network or SIM card error.
Photo of BGD
BGD
Maybe, but works for me as I plan to leave the phone off.
Also, make sure you write the number in the same format they have it there, in my case was +1416.......
