Call Forwarding on prepaid
  • Updated 2 years ago
Call forwarding on Prepaid is suppose to be included, but I tried it but it does not work what am I missing?
*21*204800****#
Nexus 6P
Photo of AndroidJohn
AndroidJohn
  • 204 Points 100 badge 2x thumb
Posted 2 years ago
Photo of rikkster
rikkster, Mobile Master
  • 68,304 Points 50k badge 2x thumb
Found some instructions. Not sure if you've already tried these steps.
1. From the home screen, tap the Phone icon
2. Tap the Menu icon
3. Tap Settings
4. Tap Calls
5. Tap Call Forwarding
6. Tap Always Forward
7. Enter the number you would like your calls forwarded to and then tap Turn On
Number to be forwarded should look like this: +15145551234
Photo of BobTheElectrician
BobTheElectrician
  • 67,236 Points 50k badge 2x thumb
Not all phones have call forwarding in the settings menu.
When I switched from post-paid to prepaid (same handset, same number and location), the MMI codes for forwarding (*21*etc) stopped working and gave error messages instead. I suspect that call forwarding does not work on prepaid and that advertising that feature is in error.
Photo of rikkster
I think you may be right Bob. TELUS mentions: Call Forwarding is not available for TELUS Prepaid accounts, so the same probably applies to Koodo.
http://www.telus.com/en/on/support/ar...
AndroidJohn
Tried booth but failed.
Call settings error
Unexpected response from network
Thanks Guys
