call forwarding
  • Updated 1 month ago
My phone was stolen and I'm wondering if theres a way to forward the calls from that phone to a different phone until I am able to go buy a new SIM.
Photo of MT Pelland
MT Pelland
Posted 1 month ago
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 138,470 Points 100k badge 2x thumb
Yes, but you'll need to contact koodo directly to do so. Tech support should have access to turn on call forwarding. Make sure you add the call forwarding add on though, or you'll be billed $0.50/minute for each forwarded call.
Photo of Robert
Robert, Mobile Master
  • 102,088 Points 100k badge 2x thumb
What if the phone is closed? Will the call forwarding still work?
Depends what you mean by closed. It'll work if the phone is turned off, but not if it's suspended or cancelled.
