Call Forward setting from outside of Canada
  • Updated 7 months ago
  • (Edited)
Hi.
I'm outside of Canada. I want to set call forwarding add-on.
I
bought the add-on online.
Now I want to set it but I have no access no my line right now to put the codes like *21*.
How can I set the call forward from another line or from the self serve or through customer service?
I will forward the calls to a Canadian number
Thanks
Photo of Greg
Greg
Posted 7 months ago
Photo of Dennis
Dennis, Mobile Master
  • 196,866 Points 100k badge 2x thumb
Unfortunately you need to be connected to the koodo network to do this.
Photo of Greg
Greg
Can I insert my koodo sim abroad and put the code? If yes, will this be counted as roaming. Note: I'm not connected to easy roam add on.
Photo of Dennis
Yes I believe that would be roaming
Photo of Dinh
Dinh, Mobile Master
  • 42,306 Points 20k badge 2x thumb
I am not sure if it applies to Telus/Koodo, but if you setup call forwarding while you are outside of Canada, you could be charged for those minutes as roaming minutes.
I would double check with a Koodo agent if it is the case.
