Call distortion
  • 2
  • Updated 2 years ago
I just got my S5 Neo a few days ago, and have noticed sound distortion ever since I made my first call.
Model number is SM-G903W
Android version 6.0.1
If I make a call, the first ring will be crystal clear, then there will be a slight click, and the sound quality goes downhill.  It sounds distorted and hollow.  I can hear them, and they can hear me, but it sounds really bad.
I've been looking around online but haven't seen anyone mention this particular behavior.  I tried wiping the cache, as outlined on this site
http://cellphoneforums.net/samsung-galaxy/t381500-samsung-galaxy-s5-neo-clear-app-cache-data%3B-wipe...
But it made no difference.
Can someone offer some help or suggestions?
Photo of Kevan B
Kevan B
  • 406 Points 250 badge 2x thumb
Posted 2 years ago
  • 2
Photo of Jonathan I
Jonathan I, Mobile Master
  • 114,364 Points 100k badge 2x thumb
It's strange that this only happens a little while after the call is connected. Perhaps it's a defective SIM card, or the phone itself?
I would try reseating the SIM card first, then reboot the phone.
If this doesn't work, bring it back to the store and exchange it, or even try to test a SIM card from their booth - if the call quality improves, then the SIM is defective. If it doesn't, the phone is probably not getting a good connection to the SIM.
It could also simply be the area you're in. Are you getting a good signal where you're located?
Let us know these details and we'll assist accordingly.
Photo of Kevan B
Kevan B
I'm in Port Hardy BC.  It's a fairly rural area, but my previous phone(Samsung Rugby) didn't have this issue, though I was using it through Telus.
I'll try re-seating the sim, and if that doesn't work head into town tomorrow and see if The Source will help me trouble shoot.
Photo of Kevan B
Kevan B
Can't be completely sure, but I think the reseating of the sim card fixed or at least improved the call quality.
It still gives that little click after the first ring, but the sound doesn't seem nearly as distorted now.
Thanks!
Photo of Jonathan I
No problem! I know SIM cards can get scratched up/damaged from repeated use so sometimes that can help.
If the problem persists, then try the other suggestions. Telus/Koodo are basically the same network so your reception should be the same. It could be a phone issue and if you're within the 15 day return period you can return/exchange it. If you're over 15 but under 30, then it would be DOA exchange only - you'd have to take the same model.
