Call Display
  • Updated 2 months ago
I have caller display on my plan however every time someone calls whether the person is in my contacts or not my screen displays "unknown". How can I fix this?
Photo of Shannan Caza
Shannan Caza
Posted 2 months ago
Photo of Dinh
Dinh, Mobile Master
  • 32,964 Points 20k badge 2x thumb
Hi Shannan,
It could be the problem of the caller,they might choose not to display their caller ID (Show my caller ID OFF).You could ask them to check.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,580 Points 100k badge 2x thumb
All plans have call display. Call display just shows the number not the name of the entity unless they're in your contacts
Shannan Caza
I have checked, every caller no matter their settings will display "unknown". Therefore, I can't even see the actual number calling!
Shannan Caza
I have a sky device, however my sister has an Iphone 5 and my mother has an android and they both have the same problem
  • 199,404 Points 100k badge 2x thumb
That's odd that it's on every phone with koodo, must be on Koodo's end then. I'll ask them and see what they say and get back to you.
Shannan Caza
Okay, thank you I appreciate it :)
Talked to Koodo and there's no issue on their end. I'm lost as to how it can be happening to 3 different devices and 2 different operating systems. I'll try and think of something but for now I'm not quiet sure.
You're with koodo mobile correct?
Shannan Caza
OK thank you for checking, and yes I am.
Photo of BobTheElectrician
BobTheElectrician
  • 62,064 Points 50k badge 2x thumb
Call display codes are listed here:
http://www.geckobeach.com/cellular/secrets/gsmcodes.php
Type    *30#     You should then see a screen message stating that call display is active.
Try calling that handset from one of your other ones that are included in your contact list.
Photo of rikkster
rikkster, Mobile Master
  • 67,084 Points 50k badge 2x thumb
Tiny correction. It's *#30# and you have to press the call soft key on the phones' dial pad to allow the MMI code to start. A message will appear 'Incoming Caller ID Service is enabled'. Press OK to exit.
Shannan Caza
After using *#30# it is telling me caller ID is disabled and when I use the code to enable it says that its a connection error or invalid MMI code (I used *30# to try and enable it)
BobTheElectrician
Are you on prepaid? Some MMI codes such as forwarding don't work.
Shannan Caza
Not it isn't. I will go to a koodo kiosk and see what they say!
