burned charger and phone
hello.i bought a samsung galaxy note 2 4 months ago.today after work i plugged the charger to my phone and after a couple of minutes it started smoking.its burned now and i can not charge my phone.does koodo replaces the phone?
Photo of Stavros Ikonomou
Stavros Ikonomou
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Robert
Robert, Mobile Master
  • 103,644 Points 100k badge 2x thumb
Koodo will definitely ask if you used the original charger which is something you should answer yes. Because if not, then it's your problem that you didn't use the good caharger. You would need to present yourself in a retail shop in order to send your phone for repair!
Stavros Ikonomou
yes i used the original charger.the original charger is burned.you think im gonna pay for that or they gonna fix it or replace it for free?
Photo of NR
NR
  • 60 Points
Good question
Photo of David
David, Mobile Master
  • 89,024 Points 50k badge 2x thumb
This is a manufacturer's warranty issue. Koodo may be able to help you with processing you warranty claim, but it is actually Samsung's responsibility to address.
Photo of Robert
If they make you pay for that then their CR is horrible. It's not their fault it burned. And IF they do make you pay for that, make the new pop out so that everyone know how horrible samsung is!
Stavros Ikonomou
thanks a lot guys.i appreciate the help
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,448 Points 100k badge 2x thumb
Was it the orignal battery or a replacement battery?
