Brought a Prepaid Data booster 2 days ago and now there's a double top up promo.
  • Updated 8 months ago
I got a 1GB data booster for my prepaid account 2 days ago and now there's a double booster promo, is there any way I can get my 1GB booster turned into a 2GB booster or get $10 refunded since now you can get a 1GB booster for $20 with the current promo.
Photo of Raboo
Raboo
  • 124 Points 100 badge 2x thumb
Posted 8 months ago
Photo of Sophia
Sophia, Mobile Master
Aye, I am afraid you may be out of luck, Raboo... but you could send a private message to Koodo on Facebook trying to see if there is anything they can do for you.... no promises but you can try!
Photo of Mayumi
Mayumi, Mobile Master
  • 115,056 Points 100k badge 2x thumb
And, Boosters don't expire as long as you renew your plan, so why not buy more booster(s) while it's available?
It's been long time since I saw the promo on prepaid last time.  You never know when they have a promo again.
Photo of Ray
Ray
  • 7,756 Points 5k badge 2x thumb
I also didn't know about the promotion, so thanks for mentioning it. I still had some data remaining from the last promotion (in 2013) but also had $40 in accumulated credit, so it came at a good time.
Photo of kp
kp
When I go to add boosters under this promo, it doesn't look the same as what's advertised.  For example, the website says a 1GB data booster plus 1GB in bonus data is $30.  But when I go to add the boosters, I see the regular booster priced at $30 and then a different 1GB "bonus" booster priced at $20.  What gives?
Photo of Mayumi
It's a double amount promo.
$30 data booster come with 1gb, but now you can get 1gb extra.
Same with $20 data booster. It's usually comes with 500mb, but you get extra 500mb = total of 1gb with price of 500mb :)
Photo of Patrick Coghlan
Patrick Coghlan
In previous promotions, the 2x amount showed up in the "add booster" window.  If I add a 1Gb booster, will I get 2Gb?
The announcement is actually confusing.  It gives you the impression that you have to activate a new account to be eligible for the booster (especially since it doesn't appear in the "add booster" window).
Patrick Coghlan
Whoops.  Nevermind.  I see the bonus boosters listed there now.
Photo of Chris
Chris
  • 2,366 Points 2k badge 2x thumb
Great to see this promo back - has been a few years!  Unlike before where you could buy as many as you want, there looks to be a limit of 1 bonus booster of each type per customer.  The system will only let you add one of each bonus booster - after you add one, it disappears from the list so you cannot add it again.
I was not aware of this UNTIL I added money (decided to go with one each first to test the waters) and then added boosters a bolded box explained it.  Thankfully I did not add more money to my account or I would have been pooched!
Now that I look at the prepaid booster URL and actively look at the "nitty gritty" section it shows below with an asterisk.  You really have to read everything carefully!
"Limit of one double value Booster at each price within each category, per customer. Offer only available to purchase online at activation or through Self Serve."
