both old and new numbers in use on same phone?
  • Updated 6 years ago
I have recently switched numbers and for some reason a few people have been receiving messages sent from my new number, but appearing as my old one. This doesn't seem to be a problem when texting people with phones other than the iPhone, such as the one I have.
Ideas?
Photo of Brendamn Gray
Brendamn Gray
  • 80 Points 75 badge 2x thumb
  • confused
Posted 6 years ago
Photo of Jonathan I
Jonathan I, Mobile Master
Sometimes there's a delay in the switch. It may take upwards of 15 minutes or longer to fix itself.
I recommend taking out the battery (if applicable) and SIM card for about a minute and resinserting it into the phone to see if it fixes anything. If you're still experiencing an issue, I recommend calling tech support. *611 from your phone or 1-866-995-6636 from any phone.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,676 Points 100k badge 2x thumb
disable both imessage and facetime from the settings menu. turn the phone off completely and power it back on. enable imessage and facetime again. they should update to the new number.
Photo of Bean
Bean
  • 2,060 Points 2k badge 2x thumb
I've talked to people who ended up with a partial port for up to a day, but it did fix itself. If it's pretty recent that you switched numbers, it's likely just that the full port hasn't taken place yet. It could just be a waiting game, but definitely try what Jonathan and Timo have suggested.
Photo of Ahmad
Ahmad
It's an iMessage thing in this situation but otherwise that would be the other situation in which it could occur
Brendamn Gray
Thanks folks! Timo`s advice worked!
