Booster for prepaid plan
If I purchase a booster add on for telephone calls, say $10 for 100 anytime minutes, is there an additional charge of 10 cents a minute, or does the 10 cents a minute come off the $10 that was initially paid for the booster?
Photo of Marlene Lavallee
Marlene Lavallee
  • 246 Points 100 badge 2x thumb
Photo of Sophia
Sophia, Mobile Master
  • 143,114 Points 100k badge 2x thumb
Hi Marlene,
When you buy a booster for $10 you'll get to use the 100 minutes without paying extra... but you'll need to keep your base plan active (probably $15 or $13.50 if you use auto top up).
It might be worth your while to spend $25 on a booster, that will give you 500 minutes and would make your calls cost $0.05 per minute :) The booster won't expire so even if it takes you 3 years to use up all those minutes, it's only money spent once :D (again, if you keep your base plan active).
Hope that helps!
Marlene Lavallee
Thanks.
