Booster for normal plan
  • Updated 1 year ago
So I will need data for only 2 or 3 months. But do not want to change my plan as it is good and not offered anymore. Can I get a few boosters to go with my plan for these months or would I be obliged to switch plans? Will probably just live without data for theses months if this is not possible, but would greatly appreciate having data though.
Thanks in advance
Photo of Trevor Pearson-Jones
Posted 1 year ago
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,676 Points 100k badge 2x thumb
Koodo does not currently offer separate data add ons for monthly plans. The only way to add data would be to switch to a new plan which includes it.
Photo of Dennis
Dennis, Mobile Master
  • 196,732 Points 100k badge 2x thumb
If you are on a Shock Free Data plan, once you reach your limit and data is stopped, you get the option to add more data
Photo of Mayumi
Mayumi, Mobile Master
  • 115,202 Points 100k badge 2x thumb
And if you are not on a Shock Free Data plan, then you can still go over your limit. Just need to pay your overages with a "Pay-per-use Rate".  (Rates are different depends on your plan )
