bluetooth wont work without data? why
  • Updated 6 years ago
Photo of HippieLongstocking
HippieLongstocking
  • 24,720 Points 20k badge 2x thumb
Posted 6 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,250 Points 100k badge 2x thumb
On which phone the Galaxy Ace 2x?
HippieLongstocking
apparently the s2x and the ace 2x
Photo of John Lee
John Lee
That's strange because my mom and dad have the S2X and they use Bluetooth many times. Are you sure you are connected to the Bluetooth device? If it is connected correctly, usually the bluetooth symbol has 2 dots around it.
HippieLongstocking
Yes everything is connected properly:) guess a factory reset is going to be needed
Yeah I didn't have that problem on Stock and I was also able to do BT file transfers. Factory Reset for sure.
Photo of Beth Standen
Beth Standen
  • 2,300 Points 2k badge 2x thumb
I have used my bluetooth headphones with my S2X when I've had my data disabled.
Photo of rikkster
rikkster, Mobile Master
  • 68,282 Points 50k badge 2x thumb
Voice commands through Bluetooth require a network connection/data to function (i.e. Vlingo/Voice Command, Voicetalk and voice-assisted Google Search). If you're not using these services, Bluetooth does not require data to operate.
