Bluetooth volume
  • 2
My Moto G will no longer control the volume on my Bluetooth speaker. It was working fine but after the system update to 4.2.2, it just stays at max volume even though on the screen it looks like the volume is going up and down. This speaker doesn't have its own volume control so I need this fixed!
Photo of moto G user
moto G user
  • 202 Points 100 badge 2x thumb
  • 2
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Are you sure your turning up and down the correct volume which would be the media volume and not the notification / ring tones volume
moto G user
Yes. when the device is paired, my volume buttons automatically control the Bluetooth volume. The Bluetooth symbol is there.
Photo of Jonathan I
Jonathan I, Mobile Master
Mine works fine with my Plantronics Legend. It has a volume hardware switch too.
Do you have a V3 micro SIM? I know that was causing issues with people's dialers after the Moto G update so maybe that affected something else too.
moto G user
Oops I meant 4.4.2
moto G user
Oops I meant 4.4.2. I found an article saying that the latest update now allows you to control the volume on your Bluetooth device as well as on the phone. So maybe this has something to do with it.but again, this causes problems for me since my device does not have its own volume control
Yah enter the blue tooth part of the settings and click on the settings icon next to your blue tooth connection and it will pop up showing to connect it to PHONE AUDIO or MEDIA AUDIO and you check off both or maybe in your case you have to check just the media one for your type of blue tooth speaker.
moto G user
Mine Only shows media audio. And when I uncheck it, Bluetooth disconnects from the speaker
It must be the blue tooth speaker your using because I just tried to hook it up to the Sony blue tooth headphones I have and it works perfectly fine.
moto G user
I thought it might be the speaker but my brother paired his iPhone to it and could control the volume from there
Totally different phone and technology though so that really doesn't mattermatter, just because a speaker works on one phone doesn't mean it will work on another from another company let alone OS
Photo of B2theden
B2theden
  • 2,626 Points 2k badge 2x thumb
Restart the phone.
moto G user
Tried that
Photo of rikkster
rikkster, Mobile Master
  • 66,988 Points 50k badge 2x thumb
You may want check with the manufacturer to see if there's a possible upgrade for the bluetooth speaker.
Photo of Myron Abolitz
Myron Abolitz
  • 62 Points
I have the same problem using Aftershokz Bluez headphones.
