Bluetooth won't turn on
  • Updated 7 months ago
My Bluetooth always worked fine, but all of a sudden it won't turn on in my settings. The little button will switch over, but it won't light up, and then when I back out it's still turned off. Any idea why I've lost the ability to have Bluetooth on my phone?
Photo of Leanne Stein
Leanne Stein
  • 80 Points 75 badge 2x thumb
  • confused
Posted 7 months ago
Photo of Dinh
Dinh, Mobile Master
  • 33,234 Points 20k badge 2x thumb
Could you restart the phone and see if the bluetooth sign shows up by itself. What type of phone are you using?, btw
Leanne Stein
This has been an issue for weeks now, the phone has been restarted several times by now. And it's a Moto G4!
Photo of Dinh
Dinh, Mobile Master
I searched the web and found this https://forums.lenovo.com/t5/Moto-G4-Moto-G4-Plus-Moto-G4/Google-Play-Protect-destroyed-Bluetooth-de...
It appeared to be a biger problem than I thought. I think it is because of the Google play, Some people found the solution by "Go to the settings menu -> Applications -> Reset application settings"
However, as it was done by Google, there must be something strange about the bluetooth software on the G4.
