Blocking harassment phone call
Can you block someone's phone no. from calling you if he/she is making harassment phone calls without changing your own phone number? If so how?
Photo of Pam jackson
Pam jackson
Posted 3 years ago
Photo of Mayumi
Mayumi, Mobile Master
  • 115,056 Points 100k badge 2x thumb
Koodo cant block phone number for you, but you can try install one of call block apps.
https://play.google.com/store/search?...
I'm using "Calls Blacklist - Call Blocker" and its works for me.
Photo of Justin Robichaud
Justin Robichaud
  • 5,002 Points 5k badge 2x thumb
No need to install 3rd Party applications.
If you have an Android phone follow these instructions on how to block that number.
http://www.wikihow.com/Block-a-Number...
If you have an iPhone try these steps.
Hope this helps and good luck with your harassing caller!
Photo of Ivan
Ivan, Mobile Master
Justin Robichaud
Doh! Forgot about those two OS'. Thanks Ivan!
