block incoming international calls
  • Updated 1 week ago
I'm sick of these spam phone calls, I would like to block incoming calls from outside of Canada.  is this possible?
Photo of James N.E. Cricket
James N.E. Cricket
  • 142 Points 100 badge 2x thumb
  • enough already
Posted 1 week ago
Photo of Sophia
Sophia, Mobile Master
Sadly, no. You might be able to find an app to help you, but mostly, incoming calls are incoming calls, you can't block them on Koodo's level I'm afraid.
James N.E. Cricket
Thanks, that was the feeling I was getting going through the website.  It's more of a nuisance really but can be a real a** pain when the kid is sleeping and stuff like that.
Photo of Allan
Allan, Mobile Master
  • 62,392 Points 50k badge 2x thumb
You can use the app called "mr number" to block numbers starting with certain digits.
James N.E. Cricket
Looked at the app, reviews are showing a lot of long time users not finding it as effective anymore, will keep an eye out for similar apps
Photo of tushar kango
tushar kango
  • 352 Points 250 badge 2x thumb
On Androids you can just tap and hold on the number and click block/report spam.
James N.E. Cricket
  • 92 Points 75 badge 2x thumb
Yeah unfortunately the numbers mutate slightly each time, I still block them but there's always a new one ready
Photo of Mats
Mats
  • 21,994 Points 20k badge 2x thumb
James N.E. Cricket
Thanks, this one is getting much better reviews than mr.number. will give it a shot thanks
Photo of Robert
Robert, Mobile Master
  • 107,280 Points 100k badge 2x thumb
You might want to change your number if that continues. You probably shared your number somewhere on the internet which explains why you are getting those calls.
James N.E. Cricket
Have considered it but reluctant to go thru the hassle and have it continue on a new number. Curious to know where it came from usually fairly selective about handing it out but I guess it doesn't take much. If it continues I think I will try the change thanks for your reply
Photo of David
David, Mobile Master
  • 93,716 Points 50k badge 2x thumb
The only number on which I get occasional telemarketing calls is my landline of 15 years. None of the other 4 lines associated with my household get spam calls. You may have better success with a new number using the newest area codes, as they are more likely to be a fresh number, not one dropped by a customer who was getting spam (or bill collector) calls.
Photo of MoFromTo2018
MoFromTo2018
  • 2,272 Points 2k badge 2x thumb
Have you tried Hiya or Truecaller? I highly recommend it. I started using Hiya (free version) a week ago and it has been helping a lot.
