blackberry wont work
My blackberry does not have the option to send pictures on it for some reason? also when I turn on my data it says that its not under my plan.... I have data and picture messaging though ;$ its a curve 9300
Photo of Paige murphy
Paige murphy
  • 172 Points 100 badge 2x thumb
Photo of Ahmad
Ahmad
You need to have a BlackBerry add-on or a data plan in order to send and receive picture messages with your BlackBerry. Unfortunately, that's just the way BlackBerry's are made. If you just want to be able to send/receive picture messages, you can add the "Data Saver BlackBerry Access" for $0 a month. This will give you access to data (which will allow your picture messaging to work). However, be careful because with the add-on you CAN incur data charges. It can be added through self-serve and takes effect immediately
Paige murphy
thank you!
Photo of Ahmad
Ahmad
Not a problem:)
