Billed for picture sent thru mms
HI,
I have 2 phone (galaxy Ace II x). I don't have data plan and don't plan to have one. I have the CANADA-WIDE TALK AND TEXT PLANS (35$)
I want to be able to send and receive picture.
I have followed this thread to disable Internet and keep only mms communication:
http://community.koodomobile.com/kood...
When I look at my billing, I see the data for the picture I sent, but also I have 0.27Mb data at the same time.
How this work ? Should I send only small picture (low res) ?
Thanx
Jonathan
Photo of Jonathan Dumaresq
Jonathan Dumaresq
  • 80 Points 75 badge 2x thumb
Photo of Jonathan I
Jonathan I, Mobile Master
I just want to start by saying that your first name is awesome. Whoever chose it when you were born is my hero.
I've noticed that even with the dual APN trick that has been posted before, one of the girls who works in our Zehrs did that exact thing (we did it for her but whatever) on her S II X and the browser would still work so she got charged for data and she doesn't like that...
The issue you're experiencing is you most likely have apps/programs that are set to auto-sync in the background once your data is enabled... so even if you didn't do it yourself, it was inadverdently used.
Go to Settings > Accounts and make sure the sync is disabled for whatever accounts you have listed there. Same thing with your Gmail. I'm assuming you have one setup already since you're using an Android.
Jonathan Dumaresq
Hi,
How this is possible if I have no apn setup ?
I have a wrond apn server without any info, and another apn with only mms.
I cannot get to internet so how I can sync anything ?
Jonathan
Photo of Jonathan I
Did you ensure that the APNs in your device are exactly as what was posted/explained to you?
