Bill is charging me for next month as well!!!!!!!!
  • Updated 10 months ago
  • (Edited)
Hi i got my koodo service on august 28th. so it was 10 days and my bill should have been 10 dollars, but it is 10+40  . there must have been a problem. Im not paying this!
Photo of maryam
maryam
  • 92 Points 75 badge 2x thumb
Posted 10 months ago
Photo of David
David, Mobile Master
  • 93,388 Points 50k badge 2x thumb
Have you reviewed your PDF invoice in Self-serve? It contains all the fine details of your bill.  Your first billing period is pro-rated from when you signed up to the billing date. You are also charged services for the upcoming month in advance This occurs when anyone signs up with a provider. Similarly, when you change a plan,  both the old plan and the new are pro-rated for the portion of the month they were active. Here’s link for you describing the process. http://help.koodomobile.com/my-bill/charges-explained
Then go to "charges on my first bill"
Photo of maryam
maryam
thnx alot
Photo of Goran
Goran, Mobile Master
  • 96,868 Points 50k badge 2x thumb
Your first bill is your pro rated amount plus your first full month. Look at page 3 of your bill and it'll break that down. Don't worry, you didn't get overcharged! Your next bill will be the normal amount and all is well.
Photo of maryam
maryam
thanx alott
