better warnings for prepaid
  • Idea
When you purchase a prepaid booster each booster should have a different warning level for example if you buy the 500 min talk booster you should be given a 30 minuet warning instead of a 10 min warning because with purchasing that talk booster you are obviously making a lot of phone calls and if you are on a long distance call that's double the minutes with higher chances of the call be dropped because you run out of minuets or you could do an automatic top up for boosters once they reach a certain level as an option
Photo of Patrick Verhoeve
Patrick Verhoeve
  • confident
There are no replies.
