Being charged for Data for when phone is not even in use, why
How is my phone accumulating data usage , for instance 12.50 MB and lots of lesser ones when I am not even using the phone?
Photo of Gerry LaMarsh
Gerry LaMarsh
  • frustrated
Photo of KaneSlavik
KaneSlavik
  • 6,464 Points 5k badge 2x thumb
Application updates, push notifications, etc.
Photo of Daniel Kim
Daniel Kim, Mobile Master
It is most likely due to background applications.
If you have an iphone, go to settings>cellular>scroll to bottom and disable whatever applications from having data access.
If you have an android, setting apps to update on wifi only is a good option. To do this, go to playstore>Playstore icon settings>under general, tap on auto update apps> select auto updates over wifi only.
Photo of Chris Petersens
Chris Petersens
All so called "smartphones" do this unless you adjusts the setting as the guys above mentioned it.
