being charged for overage on MB
  • Updated 1 year ago
i have a question .. I changed my plan to the 30/ month with 100mb and I was still charged $15 when looking at my usage it states 30.43mb.. I dont understand what I am being charged for?
Photo of sandra
sandra
  • 250 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Allan
Allan, Mobile Master
  • 56,746 Points 50k badge 2x thumb
Take a look at page 3 of your ebill. The $15 charge is more likely a charge for your prorated plan or maybe a overage charge in your minutes.
If you dont understand what the charge is still, take a screenshot of your ebill excluding any personal info and post it here and we can explain it to you.
Photo of Goran
Goran, Mobile Master
  • 90,674 Points 50k badge 2x thumb
Has your bill been generated yet? Go to page 3 to se the detailed breakdown and let us know if there's still something confusing.
Photo of sandra
sandra
14:17 Data Usage 0.25 MB $0.75 14:17 Data Usage 0.25 MB $0.75 14:17 Data Usage 0.25 MB $0.75 14:17 Data Usage 0.25 MB $0.75 14:17 Data Usage 0.25 MB $0.75 14:17 Data Usage 0.12 MB $0.00 14:17 Data Usage 0.25 MB $0.75 14:17 Data Usage 0.25 MB $0.75 14:17 Data Usage 0.25 MB $0.75 14:17 Data Usage 0.25 MB $0.75 14:17 Data Usage 0.25 MB $0.75 14:17 Data Usage 0.25 MB $0.75 14:17 Data Usage 10.00 MB $0.50 14:17 Data Usage 0.25 MB $0.75 14:17 Data Usage 0.25 MB $0.75 14:17 Data Usage 0.25 MB $0.75 14:18 Data Usage 5.31 MB $0.27 16:15 Data Usage 0.09 MB $0.00
Mar. 16, 2017 Data Usage 0.48 MB $1.50 Show more Total: $1.50
Mar. 13, 2017 Data Usage 0.19 MB $0.75 Show more Total: $0.75
Mar. 12, 2017 Data Usage 0.72 MB $2.25
The above is the data usage that indicates a $11.27 fee.. I don't use data when not connected to the internet.. Now the other day I down loaded a app but I was connected to the internet and I have 100mb in my plan.
Photo of David
David, Mobile Master
  • 89,116 Points 50k badge 2x thumb
Were you near the US border? There is an immense number of small packets of data at 2:17 pm.
Photo of Goran
And your had switched to a plan with data by this point?
Photo of David
The usage distribution is strange:
14 instances of 0.25 MB @ $0.75
1 instance of 0.12 MB @ $0.00
1 instance of 10  MB @ $0.50 > this is the in Canada Pay per use data rate
1 instance of 5.31 MB @ $0.27 >  this is the in Canada Pay per use data rate
All within 1 minute (plus or minus a few seconds)
Photo of sandra
sandra
I wasn't near the us border at all
Photo of Robert
Robert, Mobile Master
  • 103,784 Points 100k badge 2x thumb
What phone do you have? Maybe wi-fi assist was enables on your phone and that's what used data?
PS : If you're using Windows, using the snipping tool and uploading the screenshot will give clearer views of your bill (http://www.capture-screenshot.org/snipping-tool/)
Photo of sandra
sandra
I have the galaxy g530w
Photo of sandra
sandra
I don't use my phone for the internet at all . I am so confused
Photo of sandra
sandra
and if I turn my data off I cant get picture text messages
Photo of Dennis
Dennis, Mobile Master
  • 187,596 Points 100k badge 2x thumb
There is obviously some data leakage from your phone.  Do you know what apps are using data?  You can check this out in Settings>Data Usage
You can then turn off data for these apps or remove them.  However other apps may use data unknowingly in the future.
You can also get the Data block with Picture messaging add-on.  It is the surest way
Photo of sandra
sandra
sorry is picture messaging not include in my 30/ month plan I thought it was ?
Photo of sandra
sandra
I have checked the apps as you suggested and I have a android os that says it has 746KB what is this?
Photo of sandra
sandra
I have restricted all other apps
Photo of sandra
sandra
So in other words I PAID 15.00 for data that I didn't use that's great!!
Photo of Dennis
Cellphones can be tricky.  Sometimes they use data even when we dont want to.  It has happened to me in the past as well and I know it can give a feeling of helplessness since you are not entirely in control.
If you do not actively send pictures, then I would advise that you turn off your data to prevent this from happening again.
Photo of sandra
sandra
sorry but does my plan not include incoming and outgoing picture text messages?
Photo of David
Picture messaging is included ie. zero rated. However, when your data radio is on, it is possible for other data to be sent, especially OS background data not associated with any App.
Photo of Goran
It still should not have charged you if you had 100MB included at the time and wasn't roaming. You can send a private message to Koodo via Facebook or DM via Twitter to have them look at it and get it reversed if it wasn't roaming or an overage is confirmed.
The android OS sometimes has minimal use, like say if weather notification is built in and the like. Do you have data fully shut off?
Photo of sandra
sandra
I have my data shut off Goran however if I keep it off I cant open a picture text message. I also have the overage in data alert turned off and I didn't receive a notification I was going over my 100mb. when I look at my bill it has 30.43 Mb for a total however on there is a 15.00 charge on a specific date showing usage of 19.02mb?
Photo of Goran
The current 30 dollar 100MB plan will automatically shut off data usage once you hit 100% if you have notifications turned on, and will only allow more data usage if you reply to the text message that gets sent to accept additional data charges. I would definitely consider it worth it to have it on.
That does seem odd, as the overage rate should be 5 dollars per 100MB.
Photo of David
Is the data with charges from the same day as you changed plans? Wondering if it occurred during the overlap period?
