BBM add-on problem.
I just switched to a blackberry and got the blackberry messenger add-on added to my plan. But my bbm will not work unless I'm connected to wifi. Shouldn't it work no matter what? How do I fix this?
Photo of Amy Terrell
Amy Terrell
Photo of Myke
Myke
What Blackberry do you have?
You likely need to register your service books.
What BlackBerry do you have? Is it a Koodo BlackBerry? Are you on prepaid?
Photo of Ry
Ry
  • 5,552 Points 5k badge 2x thumb
Sounds like a battery pull is in your near future.
Photo of Xavier
Xavier
  • 7,610 Points 5k badge 2x thumb
Go to:
Options.
Device.
Advanced System Settings.
TCP IP.
Make sure you see bb.koodo.com under APN.
Then a battery pull and you fix it.
(There are some blackberries that don't have it set up by default so you do it manually)
________________________
I'm begging you to tell me where you're getting these frames!
Photo of Xavier
Xavier
Just google it. Blackberry 9320 emulator. Aren't they amazing?
You can actually play tru all the settings on any phone :p
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
Keep in mind the unlimited BBM add on is only for BB7 or earlier. If it's a BB10 device you need an actual data plan.
