Battery issues
  • (Edited)
I have the iphone 5 and my battery has been dying VERY quickly. (Charged it overnight, unplugged it around 7:30 AM and it is now 10:30 AM and the battery is on 85%) Anyone have any comments or suggestions on how to fix this? Any little tricks, or do I have to get a new phone?
Photo of Cat11
Cat11
  • 314 Points 250 badge 2x thumb
Photo of Robski808
Robski808
  • 1,088 Points 1k badge 2x thumb
Have you updated to 7.1 yet?
There may be a battery bug in this build, and may have to wait for a new update.
A few things to try -
Holding 2 buttons till you see the apple, to reset device
restoring in itunes after backup
Also the standard battery tips apply:
turn down brightness
turn off unused features:>bluetooth, wifi when not in use, turn off notifications and location services(big battery consumption),turn off equalizer,
Photo of Dennis
Dennis, Mobile Master
  • 196,890 Points 100k badge 2x thumb
Were you using your phone during that time? Using facebook for 3 hours can easily zap 15%
I can easily lose 10% on my 1 hour commute in the morning when I am facebooking, emailing, etc
Photo of DJ
DJ
  • 792 Points 500 badge 2x thumb
I have heard from friends that the iphone 5 is like this but the iphone 5s is not. They replaced theirs with the same. Whether this is entirely factual or not I cannot really say as I only owned one for half a day and didn't like it anyways and went back to s4.
Photo of Dennis
Im using the iPhone 5s. Battery life is basically the same between the phones
Photo of Robert
Robert, Mobile Master
  • 107,634 Points 100k badge 2x thumb
There's a lot of info around the net about this. Here's some I usually recommend
Turn off bluetooth, wifi and any other wireless when not in use
Turn off localisation service if you don't use it
Go into privacy and look at what apps request your location and close the ones you find unuseful.
Turn off siri if you don't use it
Check your background app refresh settings
Auto-birghtness on?
Sources
http://gizmodo.com/how-to-take-care-o...
http://mashable.com/2013/10/11/ios-7-...
http://snapguide.com/guides/save-batt...
