Battery Problem
I have a Samsung Galaxy Ace II. The phone keeps getting red hot (when not in use)and the battery drains very almost instantly. There is no pattern. The issue appears quite randomly. Can I return the phone?
Photo of Lisa Ballard
Lisa Ballard
Photo of rikkster
rikkster, Mobile Master
  • 68,464 Points 50k badge 2x thumb
If the phone is still under the one year warranty you can send it in for repair. If you've had it for less than 15 days, you can return it and exchange it for a different phone. How long have you had your Ace 2x? Depending on how long you've had the Ace 2x, it may be time for a new battery.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,938 Points 100k badge 2x thumb
To add, If within 30 days and it's a manufacturer defect you can exchange it for a new phone of the exact same model.
Also check out the battery and make sure it hasn't warped or expanded and if it has don't use it anymore and bring it in for repair or a new device depending on length of time you've had it or get a new battery if it's been over a year.
Photo of Ann Vandenberg
Ann Vandenberg
  • 60 Points
This is the same problem I have had. I received a new battery under warranty but need to know if I am expected to send the old defective battery back?
Photo of Noah Chauvin
Noah Chauvin
  • 160 Points 100 badge 2x thumb
If it is not a battery defect, make sureĀ  to check that you aren't leaving apps that will drain the battery open will the phone is not in use. A good app to use to help conserve battery power is Battery Doctor, look into it.
