Battery on samsung galaxy s2x doeant last long
  • 3
The battery on my phone doesn't last long at all I'm down 50% in like 3-4 hours and all I'm doing is listening to music.... I only charge my battery when it's below 20% too and I have only had this phone for like 2 months, any ideas? I close all programs I'm not using too, but and have it on half brightness and 15 second lock.
Photo of Landon
Landon
  • 580 Points 500 badge 2x thumb
Posted 6 years ago
  • 3
Photo of Aaron MacIntyre
Aaron MacIntyre
  • 10,050 Points 10k badge 2x thumb
Could be something causing a wakelock. And funny you mention music... corrupt mp3s can cause the android media server a wakelock to end all wakelocks.
Download Gsam batter monitor from the market place, let it run for the day (or atleast from when its at 100 percent charge to 15) and see what is eating all your juice
I'm willing to bet media server will be near the top.
Aaron MacIntyre
link to gsam on the market place
https://play.google.com/store/apps/de...
Photo of Daryl Martin
Daryl Martin
  • 80 Points 75 badge 2x thumb
i do not listen to music on my phone, i talk for a brief time and the battery dies
Aaron MacIntyre
Now, if it happens that media server is near the top of the applications eating your juice... They're different schools of thought on how to deal with the issue. But in reality, the best bet is to take all mp3's or other music files off your phone. There are programs you can use to search for corrupt mp3 tags and such on windows, but I haven't used any personally so I can't recommend any.
If media server is still wakelocking after getting rid of all your mp3s, a ring tone maybe causing it. Hell, wallpaper can cause media server to wakelock. It's a real crap shoot, and Google really should do something about it.
But they haven't yet. So if doing all that doesn't track it down, the easiest thing to do is a factory reset. That way, anything that could be causing media server to wakelock is gone
After the factory reset, start moving your music on to your phone in small chunks. Let the phone run for a good bit. Check to see if mediaserver is wakelocking. If it isn't, move on, add another chunk of music on. Check to see if mediaserver is wakelocking... etc etc. If mediaserver does start to wakelock at any point, you know the offending file is in that small chunk you just ported over. So delete that chunk and start porting the files in that chunk one at a time.
It's a very tedious process, but it's how it's gotta go down. Older versions of android would just not list any music if there was even one corrupt media file. I think I liked that better....
Photo of Landon
Landon
This is what it says, ill post down below
Photo of Landon
Landon
The screenshot
Photo of samsvoc
samsvoc
  • 7,686 Points 5k badge 2x thumb
A cousin of mine has the S2X with similar issues. He installed the free juice defender app and turned off all apps that weren't needed at the time. He tells me his battery life increase about 20-25%. I'm sure there are other tweets that can be done to improve battery life. Don't forget, if you're in weak signal area, your phone will crank up the power to keep a strong signal.
Aaron MacIntyre
Yeah, Juice defender is alright. Gsam is a good first step though regardless. Shows you where your juice is going, and on what specific processes.
I recommend it for any android user regardless of the phone.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,596 Points 100k badge 2x thumb
Anything that a battery app can do can be done manually. I have seen worse battery life from the them because I already do everything manually that they do & its just another app running in the background. If you don't want to do those things manually then they can be beneficial yes.
Photo of Landon
Landon
Photo of Landon
Landon
Wait so if it estimates the battery wrong, there could still be charge left in it but it shuts off?
Aaron MacIntyre
that's right
Aaron MacIntyre
also, if the phone could say its charged, when in reality it could fit in a few more percent. in.
Photo of Landon
Landon
Thats dumb, i dont even know how to install new rom or do whatever to make it back to normal
When you install a new version of Android make sure you charge the battery to full and have the device plugged in before you update. If you haven't then charge to full & do a factory reset while it's plugged in.
Aaron MacIntyre
Anyway, just to give some idea, here's some screen shots of my SII X running Slimbean 3.0 without any init.d tweaks.
I'm now running Slimbean 3.1 with certain init.d tweaks, which has seen a battery improvement. I'll try and remember to grab some screen shots next time my battery gets low.
  • 203,898 Points 100k badge 2x thumb
I've done this and it works
Photo of John Lee
John Lee
My mom had a similar problem as well. But after she turned off most applications from the "multitasking" and kept on doing that repeatedly; the battery life was fine. Also, the Samsung Galaxy S2X is getting old now so I guess the battery doesn't last as long now.
Photo of rikkster
rikkster, Mobile Master
  • 68,350 Points 50k badge 2x thumb
Buy a new battery, the age of the device has nothing to do with battery longevity.
Photo of rikkster
I wipe the battery stats (root required and latest cwm recovery) whenever I flash a new ROM, this is the best way to calibrate the ROM to the battery.
