battery apps
Do you use battery apps on android , and what is the name of the apps
Photo of Maxime Paquet
Maxime Paquet
  • 666 Points 500 badge 2x thumb
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,180 Points 100k badge 2x thumb
a lot of the time they use up more battery than they save if you are already doing manually what the apps just do automatically.
To save battery
-it's best to just keep the display as low as possibly comfortable,
-turn off gps and any other location features when not needed,
-turn off any features such as Samsung's smart stay, smart scroll, ect,
-turn your screen on time to as low as possible,
-Close apps running in the background,
-Turn on any built in battery saving features, especially ones that undercover or limit the CPU
-Turn off hepatic feedback and vibration for ringer or notifications if you get a lot of messages or calls and don't need it or hepatic feedback of keyboard and onscreen touch.
-You can also turn off auto sync and manually sync apps when you use them but you won't receive notifications unless you open said apps.
Photo of Get it solved !
Get it solved !
  • 4,044 Points 4k badge 2x thumb
Yes Maxime , as Paul said it is better to tune up the phone manually . But if you want to let an up doing that, the only one i found with acceptable results is Juice Defender , the reset are just draining the battery more than it should .
Photo of Marcel in O-Town
Marcel in O-Town
  • 3,722 Points 3k badge 2x thumb
+1 for Juice Defender. One of the best apps that I purchased....
