Battery Percentage
"Cell Standby" and " Phone Idle" both use 50% of battery power. Is this normal? Seems excessive!
A battery booster App was installed and WiFi and bluetooth are not used and turned off.. The phone is only used for texting, photos and telephone calls.
GGG
Photo of Gordon Greer
Gordon Greer
Posted 3 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
What phone is it, is it the Galaxy S4?
Gordon Greer
No. It is a HTC Desire 320 Android
Photo of Dennis
Dennis, Mobile Master
How long is your battery life?
If it is multiple days and phone idle and standby is 50% then I think that is good/normal. It means no other apps are sucking power.
Gordon Greer
Battery life is 24h with little or no use.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
If the phone sees little or no use, then yes, I would expect most or all of the battery life would be used by idle or standby processes.
Gordon Greer
Yes, this does make sense. Thanks
