Battery life iPhone 6 Plus
  • Updated 4 months ago
Since I switched to Koodo from another provider recently, the battery of my iPhone 6 Plus drains faster. I didn’t change my usage of it. Anybody else had that issue and is there something to do? Thanks for telling me if there’s a cause to this.
Photo of Nathalie Leblanc
Nathalie Leblanc
Posted 4 months ago
Photo of Dinh
Dinh, Mobile Master
  • 41,522 Points 20k badge 2x thumb
Hi Nathalie,
You could check Settings --> Battery and see which app is draining battery the most. I would also try to upgrade iOS to its latest and Reset network settings to see if it helps. It could be some issues with sticky network settings from previous carriers.
In normal situation everything should be similar between carriers. I wouldn't think there would be much difference unless you are in a weak Koodo network spot. The phone had to increase its power to maintain good signals (if you called or used mobile data a lot).
Photo of Mats
Mats
  • 21,334 Points 20k badge 2x thumb
No, never had this issue and don't believe that Koodo is the cause of what you believe you are seeing.
Nathalie Leblanc
Thank you. I will check those settings (IOS is already the latest) but I see my cell signal is not that strong with koodo ;only 2 little bars) compared to my previous carrier. I’ll see if something changes with what you suggest. Ah! I don’t use lots of data nor calls... Thank you again.
