battery issues
  • 2
Samsung galaxy core lite android
Photo of Rosslyn Macqueen
Rosslyn Macqueen
  • confused
Posted 3 years ago
  • 2
Good morning Rosslyn,
Could you be more specific about what's happening?
Thanks
Rosslyn Macqueen
So one example is last night before I went to bed I had 61% battery and in the morning the phone had turned off because of no battery life. Yesterday in a one hour period my phone went from 91% to 13 % and the phone was in my purse not used once in that span.
Photo of Mathieu Carrier
Mathieu Carrier
  • 4,124 Points 4k badge 2x thumb
Two questions, do you close all your applications? And do you often use your phone while its plugged in?
Rosslyn Macqueen
I think I always close my open apps but as far as using it when it is plugged in I definitely do that. Is that bad?
Mathieu Carrier
Well it kills the battery life faster, its like being on a laptop while the battery is charging, the battery life is reduced :) I think you just need a new battery :)
Photo of Matthew Sider
Matthew Sider
  • 2,432 Points 2k badge 2x thumb
did you clare any running apps in the background
Some times I see people use chargeing adapter are not ment for the phone this my put stress on the battery
only use samsung adapter to charge it thats if you got samsung
Rosslyn Macqueen
I use my Samsung charger but I will check on the running apps. Thanks for your help.
Photo of BobTheElectrician
BobTheElectrician
  • 67,712 Points 50k badge 2x thumb
A battery that dives almost 80% in one hour of normal use is only good for the scrapheap.
If you are still under warranty (12 months), visit a Koodo boutique to get it replaced.
Rosslyn Macqueen
Thanks
