base plan - credit card
How do you setup your base plan to come off your credit card automatically so you can add boosters?
Photo of Yvonne Millette
Yvonne Millette
Photo of Sophia
Sophia, Mobile Master
You can set that in your prepaid self service, Yvonne: https://prepaidselfserve.koodomobile....
Log in, then click "Billing" and "Automatic Top-Up"
Then just follow the instructions to add your credit card and the amount you want to top up monthly. You can choose any amount, but $15 is the minimum to renew your base plan automatically - ideal!
