bad reception at random times in same location
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: *611 or 1-866-995-6636 mentions
At home in the country...i have perfect service for months at a time and then out of no where I can send texts and have poor for 2-3 days. Have to stand in the middle of my yard to reply to a text.why is this happening?
Photo of Leah Jarvis
Leah Jarvis
Leah Jarvis
That should have said I « can't» send texts
Photo of Sophia
Sophia, Mobile Master
It almost sounds as if the cell tower is behaving a bit badly at times, Leah. But if you want Koodo to investigate, I suggest you file a ticket with them (call *611) to see if your particular neck of the woods might be having reception problems, then you'll know for sure :)
Weather conditions and interference can cause reception to drop. We are playing with forces unknown... seriously though, lol... radio frequencies/ electro static/ flares... alot of variables... magnetic conditions in the ground... some possibilities.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,212 Points 100k badge 2x thumb
When it happens, try pulling the battery and sim card for 60 seconds. If this fixes the connection for a while and then it drops again it's probably a failing sim card.
