Avoiding charges for using data
  • Updated 11 months ago
My son has a OnePlus2 and when it forces a reboot it changes the phone setting to allow data. I have a plan with no data (for good reason). We were away and had no wifi access and it forced a reboot for some reason. After it rebooted, the phone downloaded some Snapchats that must have been waiting and incurred a $5 charge for using 31 MB. It happened again a few days later and I was charged another $5 for .59Mb. That's right, .59MB !!! As far as I am concerned there should be a way to prevent any data consumption from Koodo's end, not just the phone setting. This has happened a few times and to be honest I am not going to let it happen again. Can someone from Koodo please advise or comment. I don't want to leave.
Photo of I'm Zak's Dad
I'm Zak's Dad
  • 510 Points 500 badge 2x thumb
Posted 11 months ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,596 Points 100k badge 2x thumb
Hi Zak's dad, you can log into your self serve account and put a data block on the line so data can not be used at all if you like.
I'm Zak's Dad
that's great advise. thanks. I dont see exactly where I do this though.
My Profile / Data Settings/ Notifications and Blocks...and then what?
Photo of Allan
Allan, Mobile Master
  • 61,660 Points 50k badge 2x thumb
Try restarting the phone and see if it re-appears. Also remember that if you want to use data in the future you will have to enter in the appropriate APN details.
Happy to have helped you!
I'm Zak's Dad
for sure. thanks again for the tips. hopefully when he needs data he has a job lmao!
Photo of Parkes Patsy
Parkes Patsy
  • 80 Points 75 badge 2x thumb
I am being charged $22.00 per month for the data block? Why is thst
Photo of Allan
Can you take a screenshot of where you're seeing this? Something doesn't sound right.
Do you have multiple add-ons? $2 for the data block and $20 for a different add-on?
Photo of Bernard
Bernard, Official Rep
  • 80,184 Points 50k badge 2x thumb
Patricia, you do not have a charge for $22 worth of data block. What you did buy, is a roaming add on to the US for $40, that is why your last bill was higher.
