automatic top up and balance
  • Updated 9 months ago
balance is 0 but with automatic top up, my account expired by Koodo and all my un-used minutes and data usage are gone. I wonder how it'd happen? Isn't automatic top up will allow charge from my registered credit card no matter how much balance I have?
Photo of Oasis Huang
Oasis Huang
  • confused
Posted 2 years ago
Photo of Sophia
Sophia, Mobile Master
There are two things here, Oasis Huang, one if you add auto top up AFTER your base plan expires, you need to top up manually once to "trigger" the system into renewing.
Second, you said your account expired and your minutes/data are gone - when did you last use your phone? You have 90 days to renew your base plan after it expires, so if you can still log into self service and access your account, all you need to do is top up manually to reactivate your account.
After that, auto top up will make sure your account stays active from then on :)
Oasis Huang
Hi Sophia, thanks for your follow up. Just like you said, my account was expired and then went back to active. It all goes back to normal now except that I lost data usage and call minutes, which happened a few months ago. I'm not sure what you can do for me to get them back though.
Photo of Sophia
Hmm, boosters should never expire... so when you say you lost data and minutes, how exactly do you mean?
Photo of Melissa
Melissa, Employee
  • 11,748 Points 10k badge 2x thumb
Hey Oasis! Confirming that the data and talk boosters on your account that you previously purchased are still there.
Photo of John Smith
John Smith
  • 60 Points
I just activated my prepaid for my parents. I chose a base plan of $15 and a booster of 10$ talk. I selected auto top-up of $5. Will that charge my account a total of $30 a month? Or will it only charge the $5 if i use all my minutes?
Photo of Sophia
Your auto top up will only be used to renew your base plan.. never for boosters. Your minutes are valid until you use them all, next time get the $25 talk booster for the best value :)
Photo of Meg Wheeler
Meg Wheeler
  • 20 Points
I just activated a prepaid for my dad. I chose a base plan of $15 and a booster of $5 talk, which I selected to auto top-off. I'm still not sure what I'm going to be charged every month. Is it $20?
Photo of David
David, Mobile Master
  • 88,942 Points 50k badge 2x thumb
Expect $15 to be drawn each month. The talk booster continues until consumed. Purchasing the $25 booster as Sophia suggested is the bargain choice, as the minutes remain available until consumed.
Meg Wheeler
  • 20 Points
Thanks for the answer. So you mean the $5 talk booster, which gets him 25 anytime minutes, will roll over if he doesn't use them up in 30 days? What's the point in the extra $5 auto top up once a month, then? Thanks for your help!
Photo of Hannah Smith
Hannah Smith
  • 60 Points
New here! Is there any use of balance money if I'm registered for automatic top-ups? Is it the balance money that is used for boosters?
Photo of Sophia
Yes, you can use the balance to buy boosters, or temporarily lower your auto top up amount until it's used up... whichever you prefer.
