Assigning Ringtones Nexus 4
Can I assign a different ringtone to each of my contacts? How?
Photo of Hermel LaPointe
Hermel LaPointe
  • 272 Points 250 badge 2x thumb
Photo of Myke
Myke
When you are in the details of your contact, press the menu button gand select the ringtone option. It should let you select one.
Hermel LaPointe
Yes but this assigns the same ringtone to all my contacts. I want to be able to assign a specifict ringtone to a specific contact when receiving texts
Photo of Myke
Myke
Open contact list, tap on contact, select menu button, select set ringtone.
Photo of quasarito
quasarito
Open the app called "People", select the specific contact you want to set the ringtone for. When you see the contact info, tap the menu button (located in the upper right-hand corner) and select "Set ringtone".
Hermel LaPointe
I know that it will set ringtone for ALL contacts, I want to individualize each contact as I did with my galaxies 2 and my iPhone
Photo of Myke
Myke
These ARE the instructions how to set it individually. I've done it myself on the Nexus 4 and that is how to do it.
Hermel LaPointe
This works for the phone call ringtones, I was hoping to do it for my texts notification
Photo of Myke
Myke
You never thought to mention this from the start? You will need an application like Zedge to set a specific ringtone to a contact. There isn't a way to do it by default that I'm aware of.
Photo of Myke
Myke
for texting.
Hermel LaPointe
Actually, my second entry specified TEXT. I do have Zedge installed
Photo of Myke
Myke
If you have Zedge, then you already know how to set it to a specific contact......
So I'm wondering what it is you actually need help with?
Hermel LaPointe
Try as I may, having ZEDGE does not allow me to assign specific ringtones/alerts to a specific contact.
If I may ask,? Is this site supported by Koodo? Are you a koodo employee?
Photo of Mo D.
Mo D.
  • 17,268 Points 10k badge 2x thumb
Hi Hermel,
This site is supported by Koodo but is also mostly about customers helping customers :)
Sometimes things get lost in translation so I hope you can forgive the Community for that. :)
As for setting individual ringtones, third party texting apps such as GO sms or Handcent let you customize how you text people and that includes Individual ringtones for text. I personally use Handcent.
Good luck
