Are there roaming fees when you're out of province?
  • Updated 4 months ago
Photo of Lee McNeil
Lee McNeil
  • 80 Points 75 badge 2x thumb
Posted 4 months ago
Photo of Dennis
Dennis, Mobile Master
  • 187,544 Points 100k badge 2x thumb
It depends on your plan.  If you have a canada wide plan, then no.  If you have a province wide plan then you will incure canadian long distance charges for talk.  But text and data are always canada wide
Photo of Lee McNeil
Lee McNeil
When I bought my Samsung 7 less than two years ago, I was told that I can text anywhere in Canada at any time, and I thought they've told me that I can call anywhere in Canada after 5:00pm. (I did not purchase the data)
Photo of Dennis
Then it sounds like you can talk and text any where in canada.
You could also log into self serve and look under plans to see if you have canada wide minutes or not.
Yes texting is always canada wide
Photo of Allan
Allan, Mobile Master
  • 56,726 Points 50k badge 2x thumb
You can login to selfserve and click view rate plan to see the details of your plan. You'll be looking for a spot where it says "Canada wide minutes"
