Are my canada wide minutes being used on incoming calls?
Photo of Greg Durling
Greg Durling
Posted 3 years ago
Photo of Ahmad
Ahmad
If you're on prepaid and don't have "Unlimited Canada-wide Incoming Calls" in your baseplan, then yes your canada-wide minutes from your booster will be used for incoming calls unless you have unlimited evenings and weekends and receive calls within that time frame.
If you're not on prepaid, then if you don't have unlimited incoming calls included in your plan (if its an old plan) or add-on, all incoming calls will use your daytime/anytime minutes unless you receive your calls within your evening and weekend calling period.
