Apps problem
sent my nexus to be repaired now with my old phone I cant get in my market to add FB and other apps??
Photo of Dennis Doucette
Dennis Doucette
Photo of Sophia
Sophia, Mobile Master
Did you enter your Google credentials correctly, Dennis or what error do you get?
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
If you have multiple Gmail accounts try the other one.
I have 5 Android devices at the moment and all connect to the playstore all at the same time so it's not a restriction & nothing will prevent you from accessing it so it has to be just user error upon entering your Google account.
You can also go into your settings - app manager - slide to the right to all and scroll down to Google playstore and force stop and delete data then try logging into the playstore again.
Make sure your not using a low end phone that doesn't have the playstore but a different market place for apps. I think its old LG phones but can't remember exactly.
Photo of quasarito
quasarito
What is the old phone you are using? Does the old phone phone run the minimum Android version required by the apps you want to install?
