Apps for a smart phone
I'm new to a smart phone - but I'm learning. My question is: will iphone apps works on my Samsung Galaxy SII
Photo of Jan Matthews
Jan Matthews
  • 132 Points 100 badge 2x thumb
Photo of Sophia
Sophia, Mobile Master
No, they can't Jan... but most apps that are available for iPhone are also created for Android :)
Jan Matthews
Thank you! I was just wondering:)
Jan Matthews
Now I know and can stop wondering!
Photo of Iglooman
Iglooman
  • 4,090 Points 4k badge 2x thumb
If you go to the Google Play store and search for the type of app you are looking for, you'll be amazed at what options there are. If you need some help, just let us know what kind of app you need, and I'm sure several of the Android folks here will throw in some suggestions as to what the best apps would be for your application.
Jan Matthews
Thanks - I've done that and will again but it just seems there are so many IPhone apps advertised I wondered if they would work on my phone..
Photo of Sophia
Well the most popular iPhone apps such as Facebook, WhatsApp, Angry Birds, to name a few, all have their Android equivalent. In fact, you'd be hard pressed in fact to find an app that is advertised for the iPhone that doesn't exist for Android :)
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
Yeah the best way to think of this is comparing computers.
If you have a Windows computer or an Apple computer they both have unique programs that you can't get on the other one, but they do have some that overlap. However since they are running different operating systems (Windows/OSX) you need to buy the version specific for your device, and you can't run programs made for the other device unless you get the proper version.
Hope this analogy helps :)
Photo of Ivan
Ivan, Mobile Master
Comparing smartphones to computers isn't exactly the best, as you can run virtual machines to get other OSs and apps working. Not exactly possible with a smartphone.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,312 Points 100k badge 2x thumb
No it is possible to run a different OS on a phone as well with some type of software
The only apps that are cross platform are Android apps will work on Blackberry 10 devices like the Blackberry Z10. They just need to be converted from an APK file which Android reads to a BAR file which BB10 reads, and then side loaded. All other apps can not be used across other platforms like was stated above.
Photo of Ivan
Ivan, Mobile Master
These are not guaranteed to work (and they work less often than not) and it's not a simple process for those that aren't tech savvy. You need to download DDPB and the correct JRE and everything requires admin/root privileges which I can hardly recommend to a novice user.
While we're on the subject, I use http://apps.goodereader.com/ for downloading .bar files so conversion is unnecessary. If you can't find a .bar file your need, the site will most likely have an .apk for download which you can convert using http://apk2bar.unker.net/ but I recommend converting manually and signing the file yourself for maximum compatability, though that requires additional runtimes to be installed and is far from simple.
