Anyone know where to buy a replacement battery for a galaxy note 2 in Kingston Ontario?
Title says it all!
Photo of Steve Glover
Steve Glover
  • 222 Points 100 badge 2x thumb
Immediately Idk but I always find that eBay works great if you can wait a week or so. Good deals to be had.
Steve Glover
Yeah, lots of online options. I'm hoping to find one locally. I like being able to look at it before buying to ensure I'm not getting knock-off crap.
Photo of Jonathan I
Jonathan I, Mobile Master
For buying online stuff, make sure it says OEM. Local... Good luck. No idea. Google is your friend.
I've had luck on batteries which weren't oem but to each his own. My old S2x is happily plugging away on Chinese batteries and an external charger.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
I searched all around and the best buy I found from a retailer or Carrier was Best buy and to my surprise Rogers where I got a replacement battery and external charger to jeep a battery fully charged at all times for only $39.99. So if you have either if those in your area which I'm sure Kingston does definitely check them out. I bought mine from Rogers about a year and a half ago so you might even find it cheaper from them now.
One place you do not want to go for that kind if thing is Bell, they wanted to charge me $89.99 for the exact same thing I paid $39.99 for from Rogers. I'm really not a fan of Rogers but in this case they're the best option.
Oh and the battery charger combo I got was actually the official Samsung kit.
