Anyone have any experience with external battery chargers?
Today the charger port on my s2x broke and I have to tie a rubber band around it to get it to charge.
I'm out of warranty so i was thinking of buying one of those external battery chargers and a few oem batteries.
Like this: http://pages.ebay.com/link/?nav=item....=
Does anyone have experience with these? Are they a waste of cash?
Thanks
Photo of Issa Barmawi
Issa Barmawi
  • 1,330 Points 1k badge 2x thumb
I know for iPhone there are a lot of external batteries, and I think those are good for emergency but not for regular use as I understand.
Photo of Mo D.
Mo D.
  • 17,268 Points 10k badge 2x thumb
I wouldn't buy one off of ebay... unless the quality seemed really legit.
But batteries are batteries, and they CAN be charged externally... provided the circuitry of the charger is good (hence the price vs. quality issue)
I don't see how it could be any different than charging the battery for, say, a camera :P
Your link is broken, but I see them range from $5 - $20. Might be worth a shot!
Let me know how this goes, dude, if you do proceed!
Photo of rikkster
rikkster, Mobile Master
  • 67,080 Points 50k badge 2x thumb
Sorry to hear that Chad. I dug up a couple of links that might be of interest. I haven't used one as of yet, so I really can't comment on whether it'll be a waste of money. I would want to see this product up close before I buy it to make sure it's compatible with the S2x.
http://wireless-charger-review.topten...
The Source.ca - item on sale.
http://www.thesource.ca/estore/Produc...
Thank you all, i hadn't thought about a charging mat but here is the link fixed:
Photo of mattjs
mattjs
  • 15,658 Points 10k badge 2x thumb
Also, if you're technically inclined, you can search for an OEM S2X microUSB flex cable and swap yours for a new one. I've done this a few times on other devices and its not too tricky if you know basic circuitry. Usually they're pretty cheap as well, around $10 or so.
I don't have the hands for tiny work like that but i have ac power in my truck all day so no big deal to have a few batteries lying around. But what's bothering me now is the slow charging and consumption while plugged in.
I am rooted so i wiped the cache and reistalled cm10. Still a slow charge. Starting to think the battery might be no good as well.
Photo of mattjs
mattjs
Most standard chargers output at around 0.8A. See if your phone supports rapid charging. If it does, you can get a charger that outputs 2.8A. I have a Blackberry Rapid Travel Charger and get a full charge from nothing in about 1hr.
I use a 2.1a charger
Photo of mattjs
mattjs
Something's certainly wrong. I'd pickup a new battery.
Hmmm strange been n charger all night (with rubber band) started at 14% after 8hrs its oly at 72% and it's discharging while it's plugged in. Somethings wrong here
Photo of Don Baker
Don Baker
  • 90 Points 75 badge 2x thumb
Perfectly normal according to Koodo store
Photo of Camilo_A
Camilo_A
  • 31,012 Points 20k badge 2x thumb
Hey Chad... You may also find Universal Chargers... They will be good to any battery, one day for sure you will change your phone and this will allow you to use it too... I had one before (Lost it) and worked fine...
Photo of Steve
Steve
  • 4,030 Points 4k badge 2x thumb
Most phones aren't engineered for frequent (daily) access to the battery compartment so I would think that under special circumstances it would be useful to have a fully charged battery that can be changed out in a few minutes but it doesn't seem practical as a solution for everyday charging.
Back in the old days of ni-cad batteries things were different as the battery just clipped onto the phone (and looked like part of it) but now that devices use less power and batteries are made so much better (nmh) the phones aren't made for them to be changed (or removed and replaced) every day.
Photo of rikkster
  • 66,936 Points 50k badge 2x thumb
I think smartphones today consume a lot more power simply because of all the extra hardware that cell phones from back in the day didn't have (i.e. camera, GPS, faster CPU's/GPU's, backlighting, proximity and motion sensors, larger screens, etc.).
Smartphone firmware/software allows for power to be distributed more efficiently. Lithium ion (Li-ion) batteries have been around for more than a decade and continue to be the most commonly used power source in smartphones today.
Several advantages of having lithium-ion batteries over NiMH or NiCD batteries; lithium-ion batteries aren't prone to developing memory effect when charged repeatedly or for short periods. Battery design and construction is much more compact than previous battery designs. Less likelihood of overcharging or overheating the battery due to fail safe circuitry built into the battery.
The Nokia 5110 had the option of an extended 900 mAh lithium-ion battery but was normally shipped with a 600 mAh lithium-polymer (Li-Poly) battery.
http://www.gsmarena.com/nokia_5110-7.php
The Motorola StarTac had a 500 mAh NiMH battery.
http://www.gsmarena.com/motorola_star...
The tiny Samsung Galaxy Ace has a 1350 mAh Li-Ion battery and the Samsung Galaxy S2x has a massive 1850 mAh Li-Ion battery.
http://www.gsmarena.com/samsung_galax...
Photo of Lubas Valentino
Lubas Valentino
  • 240 Points 100 badge 2x thumb
Ebay external chargers will work.
Don't listen to the other comments.
ebay price is so cheap anyway
worse case you only waste $5 to $20 and the chances it will be your money wasted is almost none
Photo of Steve
Steve
I agree. eBay rocks. You are covered by both the eBay and PayPal buyer protection plans and if you are careful to review the feedback of the seller then you likely will never need it. I've had very good success buying replacement parts and batteries, etc. While it is true some have bough what they thought were new batteries and got worn out ones that's why you need to pay attention to the feedback.
Photo of rikkster
  • 66,894 Points 50k badge 2x thumb
The standard Samsung travel charger that ships with the S2x claims an output of 5.0V @ 1.0 amp. However, I agree with mattjs 0.8 amp explanation. 2.1 or 2.8 amps? That'll definitely charge batteries in a hurry, lol! The downside is that this will stress the battery (reduction in battery's ability to hold a full charge) over time. What you're describing sounds like the battery is experiencing the effects of parasitic load and I agree, it's time for a new battery.
Photo of justin
justin
  • 1,488 Points 1k badge 2x thumb
Yup! i agree, was gonna suggest using a universal usb charger but time to recycle that battery.
regardless, here's a universal usb charger (500mah max.) from energizer
($8 before S/H):
http://www.shop.energizerpowerpacks.c...
Thanks but the port for the charger is broken hence the need to charge an extra battery outside of the phone.
Thanks again everyone
Update:
I've been using the external battery charger now for about a week. It's great. An unexpected side effect is now that I drain each battery almost completely before charging, they are lasting longer and longer due to conditioning.
Batteries typically take 4 to 6 hrs to charge and they are lasting 6 to 12 hrs evn with my high usage. I also use green power premium which also helps them last.
All an all for 12$ I'm satisfied with the external charger and I'm planning to get another one for the house so i don't have to schlep batteries all over the universe.
Samsung galaxy S 2 x
This should do the job? Just want to check before placing order, Thanks
http://www.amazon.ca/gp/product/B0058...
I have no experience with the device you posted. I have used the one I posted and know it to work.
You should get one with extra batteries so you always have one on standby
Thanks, and that is less expensive too! Thanks for your help!
Photo of Ardwinna
Ardwinna
  • 646 Points 500 badge 2x thumb
What about a product like this for on the go charging of a phone??
http://www.amazon.ca/Anker%C2%AE-Astr...
