Android System Update Info?
  • Updated 1 year ago
Is there a time frame for the Current Android System Update. My Wife's G5Neo got it last night. Mine? Nothing so far.
Thanks
Photo of stillgolfing
stillgolfing
  • 1,920 Points 1k badge 2x thumb
Posted 1 year ago
Photo of rikkster
rikkster, Mobile Master
Not that I’m aware of. Android system updates are delivered in batches so as not to overwhelm the servers. Releasing system updates in batches is useful in pinpointing software problems, if any, early on. I checked for updates on my S5 Neo after reading your post and there it was. The update took less than fifteen minutes to install and is under 300 MB in size. Try again in a couple of hours.
