Android phone roaming in korea
  • Updated 2 years ago
I was using roaming in japan which worked fine for emergency calls but when I arrived in korea, my phone can't seem to pick up the roaming for calls/ data. This happened after I set my phone on airplane mode before boarding and off the airplane mode after landing in korea. I have a blue studio phone. Do I need to call koodo to reset my phone?
Photo of Eunjung Riauka
Eunjung Riauka
Posted 2 years ago
Goto settings . . wireless and networking... more . . . mobile networks... network selection...manual
Your phone will scan for available networks... it takes about two minutes...
Your phone will show available /compatible networks
Choose one
If you don't see any then services may not be available for your device.
What's the model number of your BLU?
Eunjung Riauka
Blue studio 5.5S
Photo of Ivan
Ivan, Mobile Master
There are 2 models of your phone with different frequencies, D630U and D630L. If you have the D630U, it would work in Japan, but not Korea. If you have the D630L, it should work in both countries.
Beat me to it.. I was researching ! Oh well.
Eunjung Riauka
Wow...I do have D630U.....so that's the answer! Thks!!
Photo of Tayeb A
Tayeb A, Employee
  • 18,208 Points 10k badge 2x thumb
Hey Eunjung,
Do you still need help? You can click here: http://koo.do/1VAwPTc for instructions on how to scan for network manually depending on your Blu Phone model.
Keep us posted!
Thanks
