alarm system txt messages not going though
  • 2
  • Updated 9 months ago
I see there has been a lot of issues with this, so if someone could add eyez-on.com to the list of unblocked it would be great.  Years it worked fine and now i'm depending on my bell phone.  tsk tsk
Photo of Doc Ingraham
Doc Ingraham
  • 92 Points 75 badge 2x thumb
Posted 9 months ago
  • 2
Photo of Allan
Allan, Mobile Master
  • 57,126 Points 50k badge 2x thumb
Are you using your number, @msg.telus.com, @msg.koodomobile.com or what to receive text notifications?
Doc Ingraham
I used @msg.telus.com for some time, then it stopped working reliably (messages would come in groups hours later) , so I researched and switched to @msg.koodomobile.com and it worked great for a month then it stopped dead.  I have tried sending txts to myself and it works fine via my home email. ( should mention I was on telus and switched to koodo some time ago for cell service)
Photo of Avni Patel
Avni Patel
  • 62 Points
Although im with a different alarm system, I've been having the same problem and my alarm company's messages have been going through and I tried sending myself texts via home email and that is working as well but just not receiving alarm company txts! must be stuck somewhere in the middle which is weird!
Photo of Yoggi C
Yoggi C
  • 90 Points 75 badge 2x thumb
I am having the same issues as Doc.  Last txt received was Aug 15.  Reading treads, it appears Eyezon needs to be added to the trusted liste.  The provider uses the noreply@eyezon.com
Photo of Yoggi C
Yoggi C
I was just informed that Koodo is having gateway issues , and to use the XXXXXXXXXX@msg.telus.com and working for me
