Air time overage problems
  • Updated 1 year ago
I am being charged airtime even though I've only used up 60 min. of my 200 min. plan. I've been charged $2.00 for 4min of calling? Why is this happening
Photo of TriggerHappy .
TriggerHappy .
  • 90 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Danny
Danny
  • 3,454 Points 3k badge 2x thumb
USA call?
TriggerHappy .
I live 2 hours away from the US border and the call was 100ft away from me
Photo of Danny
Danny
I meant "call to a USA number"?
Photo of BobTheElectrician
BobTheElectrician
  • 61,920 Points 50k badge 2x thumb
Check your usage in self-serve. Do you live/travel near the US border? Your phone may be locking on to a stronger US signal and roaming may be kicking in even though you are calling in Canada.
If this is the case, Koodo normally will reverse the charges if you call *611. You can then set up your "mobile networks" to log onto Koodo only, and ignore the automatic setting.
Photo of Danny
Danny
The problem with that theory is that it would cost more than $4 for 2 mins roaming without a plan:
http://help.koodomobile.com/my-bill/charges-explained/long-distance-and-roaming-charges
TriggerHappy .
i live 2 hours away from the US border and  the call was 100ft away from me
Did you just start your service or recently change your plan?
Photo of Jonathan I
Jonathan I, Mobile Master
It's probably proration, like Chad said. Check page 3 of your bill. Do you see 2 lines in the date section? It will show the activation date to your cycle date and then the following month under it. That means you only had a small amount of minutes to use during the first month.
Photo of Carmen Laht
Carmen Laht
  • 80 Points 75 badge 2x thumb
How do I get my money back if I was prorated unknowingly?
Photo of Mayumi
Mayumi, Mobile Master
  • 112,530 Points 100k badge 2x thumb
Can you start your own post using this link?
https://community.koodomobile.com/koodo/topics/new
And we need more info about your issue.
What plan do you have and when did you change your plan?
"... if I was prorated unknowingly?"
It happens when you change your plan in mid billing cycle or when you first sign up.
