adding long distance international
is the ld international add on something I can do without affecting my existing plan?
Can I remove it if I find I am not using it...are there any penalties?
Photo of Heather Burke
Heather Burke
  • 96 Points 75 badge 2x thumb
Photo of Curtules
Curtules
  • 19,666 Points 10k badge 2x thumb
You can call customer service to add the $2 international dialer and LD saver to your current plan. Since this cannot be added via self serve (to prevent fraud) they should not charge the usual $10 service fee.
EDIT: You also have the right to remove it any time.
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,808 Points 50k badge 2x thumb
They might have changed things in Self Serve to allow the Ld saver to be added. If you can confirm this, that would be fantastic.
Zaphod Beeblebrox
Hi Heather. Just wanted to add to Curtules' accurate explanation. As long as you do not live in Manitoba, the feature is available. MB customers are only able to use a feature like the LD saver for calling the USA, nowhere else.
