Add second phone number on same phone?
  • 3
  • Updated 2 years ago
Is it possible to add a second phone number to my phone? My current number is a 514 area code, I'd like to add a second number with a 613 area code. I live outside of Ottawa, but I work in Montreal. I don't want to carry two phones.
I'm on the 56 unlimited + 2gb data plan from December.
If this isn't possible without a second SIM card, then I guess I'll just get a VOIP app for the 613 number.
Thanks for any help/advice.
Photo of Both Jack
Both Jack
  • 150 Points 100 badge 2x thumb
  • 3
Photo of Bradley Mc
Bradley Mc
  • 344 Points 250 badge 2x thumb
It depends what phone you have. If you have the iPhone or Galaxy S 2&3. It would be recommended to have one of these phones because it will make getting a second # easier.
Photo of Both Jack
Both Jack
I have the Galaxy S2.
Photo of MatB
  • 32,458 Points 20k badge 2x thumb
Some comapnies are starting to make dual-SIM phones that can hold 2 numbers, but I don't think at this stage Koodo is doing it yet!
Photo of Jonathan I
Jonathan I, Mobile Master
I would just use Dell or Google Voice to get the second phone #. Dual SIM phones aren't readily available in North America (I hear they're more popular internationally)
Photo of Don
  • 6,586 Points 5k badge 2x thumb
If you want a dual sim phone, check out Ebay. Lots of choice on there ;-)
Photo of Yannick
  • 43,998 Points 20k badge 2x thumb
Hi there, if you're eligible you could add another subscriber on your account. You would need another SIM card though and swap them on your handset, which will not be convenient. However, we can't provide a 2nd number for one subscriber.
Photo of laura t
laura t
  • 60 Points
Would it be possible to get a second number and just have it forwarded to the phone?
Photo of BobTheElectrician
  • 57,040 Points 50k badge 2x thumb
Yes. Any VoIP service can do that relatively cheaply, so shop around. Most can also provide you with 800-service.
