add on for data $5 for 750 mb
  • 3
  • Idea
  • Not Planned
Photo of Darshak Makadia
Darshak Makadia
  • 90 Points 75 badge 2x thumb
  • 3
Photo of John Burke
John Burke, Mobile Master
Details outlining the reasoning behind this suggestion?
Personally I see no need for dissecting the blocks of Data - 500MB or 1GB is enough of a division already.
Photo of Myke
Myke
This won't work. The rate plans either have pay per use data or data built in. There isn't a way to add on data addon amounts without doing some restructuring, which is time and $$$.
Photo of quasarito
quasarito
I agree. The Canada-wide Talk & Text plans already have data tiers for the occasional user so there really is no point in having an add-on when the tiers will bucket you according to the amount of data used.
The Canada-wide Data plans have a fixed data amount per billing cycle and an overage bucket if you occasionally surpass your allotted amount. No add-on necessary here either.
The add-on idea is redundant as there are mechanisms in place for additional data already. If the person is suggesting cheaper data tiers, then that is a different story.
Photo of Curtules
Curtules
  • 19,666 Points 10k badge 2x thumb
I don't think Koodo has any plans for an optional data add-on, but if they did I doubt you'd get that much data for just $5.
Photo of Robert
Robert, Mobile Master
  • 103,372 Points 100k badge 2x thumb
The only thing you would get is 10$/extra GB. Which is not as good as you're suggesting but it would fit your needs no?
Also, what plan are you on adnare you a QC resident? Cause if yes, if you upgrade from the 40$ plan to the 45$ plan you get 800MB more than the 40$ for only 5$ .
