Add on minutes to phone on monthly plan
I would like to buy add on minutes for a phone that is on a monthly plan - is that possible?
Photo of Carol
Photo of Ahmad
  • 96,062 Points 50k badge 2x thumb
There are no add-ons for minutes anymore. They got rid of them quite a while ago. you'll have to use the pay-per-use rate (approx $0.40/min depending on your plan).
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
Hi Carol,
At this time Koodo doesn't offer an add on for additional minutes. The only way to add more minutes is to go up in price plan unfortunately.
Hope that helps answer your question
Photo of Dennis
Dennis, Mobile Master
  • 178,292 Points 100k badge 2x thumb
NOTE: If you up your plan during your current billing cycle your minutes will be pro-rated until this point (giving you less mins and increased overage). Your new upgraded plan would also have pro-rated minutes to use for the remaining billing cycle unless you upgraded to an unlimited plan.
